WebPinpoint will not install from a client session on webserver with Windows Server 2008..
  • WebPinpoint will not install from a client session on webserver with Windows Server 2008..
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:43 AM
  • When the first graphic panel is launched from a client session, WebClient does not install.
  • When an attempt is made to reduce the IE security settings, the security level sliders do not respond and the default security level remains at High.
Windows Server 2008
WebClient
IE ESC (Internet Explorer Enhanced Security) is enabled.
Disable IE Enhanced security and launch the pinpoint graphic.
  • 12306
