WebClient login screen has the TAC webClient background, but no login fields
  • WebClient login screen has the TAC webClient background, but no login fields
  • Alan_Wood
    Alan_Wood
  • sesa119747
    sesa119747
‎2018-09-06 02:46 PM
Last Updated: Admiral Alan_Wood Admiral ‎2022-11-11 12:41 PM
WebClient login screen has the webClient background, but no login fieldsWebclient Logon.jpg
Andover Continuum
webClient
This typically happens when webclient has been installed prior to IIS, so .Net framework does not get registered with IIS.
The resolution is to run the regiis.exe command as follows:
From a DOS Command Prompt (as an admin)
For Windows 2000 Professional it is:
"c:\WinNT\Microsoft.NET\Framework\v1.1.4322\aspnet_regiis.exe -i"
"c:\WinNT\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe -i"
For Windows XP Professional, Windows Server 2003 it is:
"c:\windows\Microsoft.NET\Framework\v1.1.4322\aspnet_regiis.exe -i"
"c:\Windows\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe -i"
For Webclient 1.94 and above, .Net Framework 4 is used
"c:\Windows\Microsoft.NET\Framework\v4.0.30319\aspnet_regiis.exe -i"
Once this command is run the normal login prompt will be presented.
Tags (11)
  • .net
  • 3127
  • AlanWood22
  • box
  • dotnet
  • framework
  • login
  • password
  • regiis
  • username
  • webclient
