Web browser will not allow access to SP-C web interface via HTTPS connection due to TLS error
  • Web browser will not allow access to SP-C web interface via HTTPS connection due to TLS error
  • RandyDavis
    RandyDavis
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2022-03-23 10:51 AM
on ‎2022-03-23 10:51 AM
Cannot access SP-C web interface due to TLS error.
Chrome error: ERR_SSL_VERSION_OR_CIPHER_MISMATCHChrome error: ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Edge error: ERR_SSL_VERSION_OR_CIPHER_MISMATCHEdge error: ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Firefox error: SSL_ERROR_UNSUPPORTED_VERSIONFirefox error: SSL_ERROR_UNSUPPORTED_VERSION
EcoStruxure Security Expert
Security Expert Controller (SP-C)
As per the table below, SP-C with OS  2.0.24 or lower does not support TLS 1.2.  A modern web browser will block access to sites that use TLS 1.0 or 1.1.
 If TLS 1.2 support is required, an OS upgrade to 2.0.25 or higher is required:
  1. Upgrade the controller's firmware to a version that supports HTTPS, as explained in:
    AN 314 Security Expert - HTTPS Connection to the Security Expert Controller - Integration Guide
  2. If the current SP-C OS version is 2.0.24 or lower, contact Schneider Electric support to acquire the upgrade package and further documentation.
  • EcoStruxure Security Expert
  • MahmoudSayed22
100% helpful (2/2)
