Web Client using an HTTPS connection is slow to update once logged in
  • Web Client using an HTTPS connection is slow to update once logged in
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2020-10-12 05:56 PM
When connecting to Web Client using a secure HTTPS connection and logging in, the web page updates very slowly. When browsing between menus, lists of objects and/or details will update slowly or not at all.
EcoStruxure Security Expert
Security Expert Web Client
The Maximum Worker Processes parameter in the Internet Information Services (IIS) Manager is set too low to service Web Client. It has been seen in some instances that this was set to a value of 1 which will impede the performance of the client.
The Maximum Worker Processes parameter must be set to a value of "10".
  1. Open the Internet Information Services (IIS) Manager by searching for "IIS" in the Windows search bar.
    Internet Information Services ManagerInternet Information Services Manager
  2. Navigate to Application Pools, right-click DefaultAppPool, and select Advanced Settings.
    DefaultAppPoolDefaultAppPool
  3. Scroll down and change the Maximum Worker Processes to "10".
    Maximum Worker ProcessesMaximum Worker Processes
  • EcoStruxure Security Expert
Tags (4)
  • AdamSteele20
  • AdamSteele22
  • AdamSteele24
  • AdamSteele25
