Vista conversion tool creates Xenta devices with an empty application
  • Vista conversion tool creates Xenta devices with an empty application
  • RobertAndriolo
    RobertAndriolo
  • PeterLarsen
    PeterLarsen
Spock PeterLarsen Spock
‎2022-05-17 08:32 PM
Last Updated: Guinan RobertAndriolo Guinan ‎2022-05-17 08:53 PM
When the Vista export file is converted using the Vista conversion to an EBO Server the Xenta devices are created with an empty application.
TAC Vista, EcoStruxure Building Operation
Vista Conversion tool
The user name that was used to log into Vista Database to run the Database export does not have full access to the Xenta devices Function Block Program.
Log in with the System user that has full access to the Vista Database and export the database for the conversion tool to use.
Labels (2)
  • PeterLarsen22
