Vista SmartStruxure Interface service not found
  • Vista SmartStruxure Interface service not found
  • Jonas_Brissman
    Jonas_Brissman
  • Anonymous user
‎2018-09-11 06:53 AM
Last Updated: Janeway Jonas_Brissman Janeway ‎2024-04-30 12:05 AM
Opening the Vista SmartStruxure Interface setup, found in the status box, message "service not found" is displayed.
  • TAC Vista server
  • Vista SmartStruxure interface
Some dll may be missing causing the service could not start.
  1. Manually run the VistaInterface execution file. By default TACVistaSmartStuxureInterface.exe file is stored in C:\Program Files\Schneider Electric\TAC Vista SmartStruxure Interface 1.0.5.
  2. Double click on the TACVistaSmartStuxureInterface.exe file, if the service could not be started, it will pop out an error message window.
  3. If it is a dll file missing, can find the corresponding dll on the internet, and solve this issue. If the error message shows some other error, please make a copy of the error message and contact the local support team for further assistance.
Labels (2)
Tags (2)
  • 14647
  • JonasBrissman24
