VisiSat - Version 2.1 Build 196, installed with Visio 2010 / Visio 2016.
  • VisiSat - Version 2.1 Build 196, installed with Visio 2010 / Visio 2016.
  • Gary
    Gary
  • sesa125819
    sesa125819
‎2018-09-10 12:07 PM
Installing VisiSat 2.1 Build 196, when using Visio 2010, or Visio 2016.
Satchwell MicroNet
  • Visio 2010
  • Visio 2016
  • VisiSat 2.1 Build 196
Having installed VisiSat 2.1 Build 196, the customer cannot see any of the VisiSat tools.
Visio 2010 is unlikely to be available Visio 2016 may be.
To install VisiSat 2.1 Build 185, when Visio 2010 is being used, please carry out the following;
Install Visio 2010.
  1. Start Visio 2010.
  2. Select the "Options" menu
  3. Select the "Trust Centre" menu
  4. Select the "Trust Centre Settings" menu
  5. Select the "Macro Settings" menu
  6. Choose "Enable All Macros" and save the changes.
PLEASE NOTE - Visio 2016 is not supported by VisiSat 2.1 Build 196, and therefore has not been tested.
Install Visio 2016
  1. Start Visio 2016
  7. Select the "File Block Settings" menu
  8. Uncheck the boxes of the files you wish to open/save.
  9. Shutdown Visio and restart Windows.
    Restart Windows.
    Install Visisat.
  10. When opening Visisat you should now see the VisiSat tab in Visio 2010/2016
Please note, an occasional error has been seen when selecting the VisiSat "Options" menu, this error does not appear to cause any problems.
  • Satchwell MicroNet
Tags (5)
  • 8363
  • cet
  • dll
  • load
  • unable
