Viconics SE7200 configuration option
  • Viconics SE7200 configuration option
  • SESA150559
    SESA150559
‎2018-09-06 10:32 AM
Is it possible to configure the On/Off output as a PWM output?
Viconics
SE7200
SE7200C5545W
In some applications its desirable that the output is configured as PWM.
The main On-Off outputs cannot be set as PWM, they go up to 8 CPH.
However, the BO5 output can be On/Off (4 CPH) or PWM (10sec. cycles).
Labels (2)
  • EcoStruxure Building Expert
  • Field Devices
  • 12877
