Veris HW sensor part number for displaying both the temperature and humidity readings on the sensor's LCD
  • Veris HW sensor part number for displaying both the temperature and humidity readings on the sensor's LCD
  • RyanSuar
    RyanSuar
‎2018-09-10 05:26 AM
Veris HW Series deluxe wall humidity sensors
There is a need to display both the humidity and temperature readings on the sensor's LCD
In order for unit to display both temperature and humidity, use the TA or D temp selection in the part number.
Refer to the HW series sensors datasheet.
  • Field Devices
  • 6705
