Verifying Database returns Table Differences on a Server Client system
  • Verifying Database returns Table Differences on a Server Client system
  • Derrick_Ratliff
    Derrick_Ratliff
  • CraigEl
    CraigEl
‎2018-09-10 06:44 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 05:52 PM
Performing a database backup and restore is still functional.
I/NET Seven
Server PC, DbCreate
When the I/O server is shut down before all of the client PCs some objects were opened and never closed.
  1. Restart I/NET on the Server PC
  2. Shut down I/NET on all the client PCs
  3. Shut down I/NET on the Server PC
  4. Use Db Create to Verify Database
NOTE: The Server Client configuration should only be used if you expect the Server to run 100% of the time.  If you wish to perform backups or other maintenance use the process above or use the tool found on the Buildings Business Community here.
  • TAC INET
  • 5909
