Using the 'PowerFail' System Variable in b3 Controller Script Programs
  • Using the 'PowerFail' System Variable in b3 Controller Script Programs
  • GavinHe
    GavinHe
  • Benji
    Benji
  • JohnBoehmer
    JohnBoehmer
‎2018-09-10 02:02 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-27 02:42 PM
When manually binding the PowerFail system variable via a Numeric Input in the program header of a b3 controller, the value shown in the Binding Variables window may appear incorrectly (e.g., 1536 instead of a binary value like 1 or 0).
  • b3 controllers
  • Script Program Editor
The Script Program Editor for b3 controllers does not recognize PowerFail as a predefined system variable. As a result, it displays an unexpected integer value in the Binding Variables window.
Despite the incorrect display (e.g., 1536), the PowerFail variable functions correctly when bound to a Numeric Input. During compilation and execution, the system properly interprets the value.
Best Practices for Scripting
  • Treat PowerFail as a binary input: use logic based on True/False or ON/OFF.
  • Ignore the displayed integer value in the Binding Variables window.
  • Be aware that PowerFail is only active for one scan cycle immediately after power is restored following a loss.
Example Usage
Additional Notes
  • This behavior is expected and does not impact the actual functionality of the PowerFail variable.
Tags (2)
  • 18527
  • GavinHeward25
