Using a USB-Serial Lead to SDCU a Sigma Controller
  • Using a USB-Serial Lead to SDCU a Sigma Controller
  • CraigEl
    CraigEl
  • DavidChild
    DavidChild
‎2018-09-06 01:22 PM
Last Updated: Administrator CraigEl Administrator ‎2025-11-05 09:05 PM
Your laptop does not have a native serial (RS232) port. Can a USB-to-Serial adapter be used to connect to a Sigma controller via the SDCU utility?
Satchwell BAS & Sigma
  • Satchwell Sigma Controllers
  • SDCU
Modern laptops typically omit legacy RS232 serial ports in favor of USB interfaces. The SDCU utility requires a serial connection to communicate with Sigma controllers. Without a native serial port, a USB-to-Serial adapter is needed to emulate the required RS232 interface.
Yes, a USB-to-Serial RS232 adapter can be used to SDCU a Sigma controller. Follow these steps to ensure proper setup:
🔧 Step-by-Step Instructions
  1. Connect the USB-to-Serial Adapter
    • Plug the USB-Serial lead into your laptop.
    • For first-time use, install the driver provided with the adapter (typically from the manufacturer like FTDI or Prolific).
  2. Verify COM Port Assignment
    • Navigate to:
      My Computer > View System Information > Hardware > Device Manager > Ports (COM & LPT)
    • Note the COM port number assigned to the adapter (e.g., COM3).
      ⚠️ This port number may change each time the adapter is reconnected.
  3. Connect to the Controller
    • Use the SDCU lead to bridge between the USB-Serial adapter and the Sigma controller.
  4. Launch SDCU Utility
    • Open the SDCU software.
    • Set the communication port to match the COM port identified in Step 2.
  5. Configure the Controller
    • Proceed with controller configuration as required.
SDCU Cable Pinouts
✅ Compatibility Notes
  • Supported Adapters: FTDI and Prolific chipsets are commonly compatible.
  • Troubleshooting Tip: If communication fails, verify driver installation and COM port settings. Try a different USB port if needed.
🔗 Related Articles
  • USB Serial Adapter Compatibility with Sigma
  • Satchwell BAS & Sigma
Tags (3)
  • 6300
  • CraigEllis23
  • CraigEllis25
