Using Xenta Controllers with a Tridium Jace
  • Using Xenta Controllers with a Tridium Jace
  • RandyDavis
    RandyDavis
‎2018-09-06 03:08 PM
Last Updated: Guinan RandyDavis Guinan ‎2023-11-06 11:41 AM
TAC Vista, TAC IA Series
  • Xenta programmable controllers
  • Xenta 280, 281, 282, 283, 300, 301, 302, 401, 401:B
  • Tridium AX / N4 Jace
By default, the Tridium Jace acts as a network manager which will disrupt controller addresses, SNVT bindings, and Group bindings previously set up in LonMaker.
 To disable this feature provide these steps to a Tridium Integrator:
  1. Use Niagara WorkBench
  2. Connect to Jace
  3. Under the Services Folder, find "LonNetwork"
  4. Go to  "Local Lon Device"
  5. Set the "External Config" property to "true"
  6. Hit "Save"
Tags (2)
  • 1902
  • RandyDavis23
