Using 6 digits address register with the modbus xdriver
  • Using 6 digits address register with the modbus xdriver
  • Alan_Wood
    Alan_Wood
‎2018-09-06 12:48 PM
Some modbus device documentation indicate that there are 6 digits in a register to obtain certain information
Continuum
Xdriver
Modbus
The Modbus xdriver only allows for 5 digits
The modbus range is from 0-65535, so 6 digits is too large
Some PLCs used the 40,000 and 30,000 notation which embeds the function code in the address.
For example:
30,001= function code 4 start address 0
30,234= function code 4 start address 233
40,001= function code 3 start address 0
  • 7107
0% helpful (0/1)
