User names with special characters are not being imported correctly
  • User names with special characters are not being imported correctly
  • AdamSteele
    AdamSteele
  • SangKim
    SangKim
Lieutenant | EcoXpert Master SangKim Lieutenant | EcoXpert Master
‎2019-08-05 07:34 PM
on ‎2019-08-05 07:34 PM
Importing a User CSV file with special characters (i.e. PEÑA or DÍAZ) ends up with unknown characters.
Example showing Imported Users with unknown charactersExample showing Imported Users with unknown characters
Security Expert
  • Security Expert Client
  • Security Expert Data Sync Service
The Security Expert Data Sync Service requires UTF-8 encoded CSV files.
Import the CSV file again with it re-encoded as UTF-8. Follow the below steps to re-encode the file:
  1. Open the CSV file in Excel. Then select Save As.
  2. In the Save As Type drop down menu, select CSV (Comma Delimited)."
  3. Click the Tools menu and select Web Options.
  4. In the new dialog box, select the Encoding tab.
  5. Find the Save this document as dropdown menu and select Unicode (UTF-8), then click OK.
  • EcoStruxure Security Expert
  • sangkim19
100% helpful (1/1)
