Upgrading from rev 2.1X to 2.16
  • Upgrading from rev 2.1X to 2.16
  • sesa139513
    sesa139513
  • Roger_Bently
    Roger_Bently
‎2018-09-06 02:38 PM
I/NET 2.1x site
desire to upgrade to newer release of I/NET
When upgrading from revision 2.10 and higher to 2.16, there is an additional step that is required. If you get to 2.16, start I/NET and only question marks are displayed when you connect to the controller, or it takes a long time to connect. There are two work-around things to try for this.
  1. Run the 2.15 patch or reinstall 2.15 and then upgrade to 2.16.
  2. Run DB Create, force an upgrade to the database and verify that the database version does in fact match the revision that you are running.
  3. To get to the revision number, click on the header on DB Create, then select about, it would show this information.
The other work around is to just close I/NET and I/O Server and restart them again.
  • TAC INET
  • 3425
