Upgrading Vista system with TAC Danduc OPC server
  • Upgrading Vista system with TAC Danduc OPC server
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 01:13 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-10-28 09:51 AM
Does TAC Vista 5.1.6 work with a TAC Danduc OPC server?
What OS works with TAC Danduc OPC server?
TAC Vista
TAC Vista 5.1.6
TAC Danduc OPC server is tested on many sites in Denmark using Vista 5.1.6.
Only 32-bit OS works with TAC Danduc OPC server.
TAC Vista 5.1.6 is works fine with TAC Danduc OPC server.
All operating systems also work fine as long as they are 32-bit.
  • 6308
