Upgrading SecureStruxure to Security Expert
  • Upgrading SecureStruxure to Security Expert
  • AdamSteele
    AdamSteele
  • Benji
    Benji
‎2018-09-10 01:18 PM
Last Updated: Guinan AdamSteele Guinan ‎2022-10-05 09:45 PM
A previous version of the client software badged SecureStruxure is installed, and needs to be upgraded to Security Expert.
EcoStruxure Security Expert
  • Security Expert
  • SecureStruxure
The offer had the name changed between versions and it's not straight forward how to update the software, and databases, to the newer version.
SecureStruxure can be upgraded to Security Expert by following these steps:
  1. Contact Product Support to upgrade the site license to Security Expert..
  2. Backup the SecureStruxureOperations and SecureStruxureOperationsEvents databases via SQL Server Management Studio.
  3. Uninstall SecureStruxure.
  4. Rename the SecureStruxureOperations and SecureStruxureOperationsEvents databases to SecurityExpert and SecurityExpertEvents
  5. When you run the Security Expert installer, use the new Security Expert SSN. You will need to point Security Expert at the MS SQL database instance you were previously using for SecureStruxure (this is likely "localhost\SECURESTRUXURE"). The installation wizard should pick up the databases and upgrade them, retaining all the SecureStruxure programming.
  6. Log into Security Expert and re-license the software by going to the About | License menu option..
    1. If you are unable to connect to the license server (no internet connection), you can use the manual method for registering a license.
  • EcoStruxure Security Expert
Tags (4)
  • 19353
  • AdamSteele20
  • AdamSteele22
  • AdamSteele24
100% helpful (1/1)
