Upgrading DPU 7910 and DPU 7920's with Eproms.
  • Upgrading DPU 7910 and DPU 7920's with Eproms.
  • Roger_Bently
    Roger_Bently
‎2018-09-06 01:23 PM
Procedure to replace EPROM when doing an upgrade.
All versions of I/Net software using Access Control on DPU 7910 and EPROM version of the  DPU 7920.
Upgrading the software and hardware on a system which work with each other.
The following steps should be followed to ensure that the devices do not get damaged during the process of the upgrade:
  1. Remove power form the device
  2. Carefully remove the Eproms using the appropriate tools
  3. Replace new EPROM with correct orientation (notch on the chip)
  4. Power up the device again and hit the reset button.
  5. Verify that the transmit and receive lights are on and communications to the MCI has been re-established.
  6. Read a card and verify that the transactions are coming into AMT.
  • TAC INET
  • 6000
