Upgrade failed, server not stopping
  • Upgrade failed, server not stopping
  • Jonas_Brissman
    Jonas_Brissman
  • RobertAndriolo
    RobertAndriolo
Janeway Jonas_Brissman Janeway
‎2023-01-09 04:26 PM
Last Updated: Picard RobertAndriolo Picard ‎2024-07-24 04:18 PM
During an Enterprise Central or Enterprise Server upgrade, the upgrade is halted with a message that the "server has not stopped".
"Error: server state 'ServerShuttin'"
Upgrade Fails on Server not stopped state = starting
  • Building Operation Enterprise Central
If the last shutdown of the ES/EC process was due to a crash or if it was stopped through the task manager, the current ES/EC server state is not updated, causing the upgrade to fail.
  1. Check that the server process is stopped: SE.SBO.EnterpriseServer.exe or SE.SBO.EnterpriseCentral.exe in the Task Manager.
  2. Open the database folder for the server in question, e.g., %programdata%\Schneider Electric EcoStruxure\Building Operation 3.2\db
  3. Edit the file: nsp_servers.serverstate
  4. Change the text "ServerShuttin" or "ServerRunning" to "ServerStopped".
  5. Save the file and try again (retry)
Tags (2)
  • JonasBrissman23
  • RobertAndriolo24
