Updating Firmware of SP-MNR2
  • Updating Firmware of SP-MNR2
  • RandyDavis
    RandyDavis
  • JamesMorgan
    JamesMorgan
Lieutenant JG JamesMorgan Lieutenant JG
‎2022-08-03 11:25 AM
on ‎2022-08-03 11:25 AM
Unable to find firmware update instructions in the SP-MNR2 installation guide
EcoStruxure Security Expert
  • Security Expert Controller
  • Security Expert SP-MNR2
TFTP is needed to upgrade firmware
What you need:
  • TFTP WinAgent software (tftp.exe)
  • PRT-MNR2-DIN firmware
    Download these files to the same folder(ex c:\fw)
Steps:
  1. log into SP-MNR2's built-in web interface (default: 192.168.1.3)
    (if you are having trouble connecting to the interface, review the SP-MNR2 installation guide p.16-18)
  2. Browse to the MNR2 module and select the ‘Device’ page. Put the module into boot mode as seen below
  3. Open Command Prompt (Win key+R; cmd, Enter)
  4. Type: cd c:\fw
  5. Then Type: tftp -v -i <MNR2_IP_address> PUT <MNR2_Firmware_Filename.bin>
  6. The command window should fill up with ‘packet received’ messages while the file transfer is being processed.
  7. Bring your SP-MNR2 back online. You should find that the firmware version is now updated
  • EcoStruxure Security Expert
  • JamesMorgan22
100% helpful (1/1)
