Unlocking a door after First Valid Access
  • Unlocking a door after First Valid Access
  • Alan_Wood
    Alan_Wood
‎2018-09-06 12:40 PM
At times there is a need to keep a door unlocked with a schedule, but this can cause a problem if there is extreme weather and no one is at the building.
  • Continuum
  • AC1/AC1A
  • AC1 Plus
  • ACX5740
  • ACX781
Leaving a buildings door open when there is no one at the building is a security risk. This work around will take care of this problem.
The way around the issue of having a door open from a schedule when no one is in the building due to inclement weather is to set up a Plain English program to set the Unlock InfinityNumeric On only if the schedule InfinityNumeric is On AND there has been a valid access to the door.
InfinityProgram
FlowType Loopin
Objects required
  • Door1 - the name of the door to control
  • SchedNum - InfinityNumeric controlled by the schedule
  • UnlockNum - InfinityNumeric linked to Door1 Door Unlock Schedule
Code Example (This must be edited to reflect the door name and schedule numeric that has been created)
WaitForSched:
     UnlockNum=Off
     If SchedNum=On then GoTo WaitForValid
WaitForValid:
     If Door1 ValidAccess is True then
        UnlockNum=On
        GoTo WaitForEnd
     Endif
WaitForEnd:
     If SchedNum=Off then GoTo WaitForSched
  • 7319
