Continue
  • My Subscriptions
  • Events
Unlocked door status does not show that it has been trigger by a fire alarm
  • Unlocked door status does not show that it has been trigger by a fire alarm
  • Hernan_Urueña
    Hernan_Urueña
  • AdamSteele
    AdamSteele
Hernan_Urueña Mentor
‎2023-06-29 11:12 PM
Last Updated: AdamSteele Champion ‎2023-06-29 11:41 PM
After configuring a fire alarm using the Emergency Egress programming in AN 208 Security Expert - Emergency Egress - Integration Guide, doors that have a Bond sense input configured do not show the same status as a door without a Bond sense input when there is a fire alarm.
Door input options settingsDoor input options settings
Instead of showing the expected "Unlocked By Fire Alarm" status the doors with Door sense inputs show "Not Locked".
EcoStruxure Security Expert
  • Security Expert
  • SP-C
  • SP-C-IP
  • SP-ACX
  • SP-AC1
The Bond sense input was not wired up and did not show the actual lock output status. This input is used to detect the position of the door lock. When it is opened the door status will change to "Not Locked", this was overriding the "Unlocked By Fire Alarm Status".
Check the wiring of the Bond sense input and ensure it correctly indicates the position of the door lock.
  • EcoStruxure Security Expert
Tags (3)
  • HernanUruena23
  • HernanUruena24
  • HernanUruena25
