UniCast or Multicast
  • UniCast or Multicast
  • CraigEl
    CraigEl
  • Chris_Asbury
    Chris_Asbury
  • sesa139513
    sesa139513
‎2018-09-06 09:37 AM
Last Updated: Administrator CraigEl Administrator ‎2022-10-12 03:24 PM
Does Building Operation use Unicast or Multicast?
  • Building Operation Automation Server
  • Building Operation Workstation
Definitions:
Unicast packets are sent from host to host. The communication is from a single host to another single host. There is one device transmitting a message destined for one receiver.
Multicast is a protocol for use with IP. Multicast enables a single device to communicate with a specific set of hosts, not defined by any standard IP address and mask combination. This allows for communication that resembles a conference call. Anyone from anywhere can join the conference, and everyone at the conference hears what the speaker has to say. The speaker's message is not broadcasted everywhere, but only to those in the conference call itself. A special set of addresses is used for multicast communication.
Broadcast is when a single device is transmitting a message to all other devices in a given address range. This broadcast could reach all hosts on the subnet, all subnets, or all hosts on all subnets. Broadcast packets have the host (and/or subnet) portion of the address set to all ones. By design, most modern routers will block IP broadcast traffic and restrict it to the local subnet.
Building Operation is using only IPv4 and therefore Unicast only. This may change when Building Operation begins using IPv6. At that time, a site may want to use the IPv6 multicast features to address groups of targets.
Tags (2)
  • 15996
  • CraigEllis22
