Understanding Hosted Backup Options in EcoStruxure Access Expert V3
  • Understanding Hosted Backup Options in EcoStruxure Access Expert V3
Admiral Alan_Wood Admiral
‎2024-08-22 06:20 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:31 AM
An explanation of Hosted backup options is needed to understand which objects are backed up and which are not.
Access Expert Hosted V3
Warning
Potential for Data Loss: The steps detailed in the resolution of this article may result in a loss of critical data if not performed properly. Before beginning these steps, make sure all important data is backed up in the event of data loss. If you are unsure or unfamiliar with any complex steps detailed in this article, please contact Product Support for assistance.
It's important to understand the backup options available for an instance.
By default, each instance includes a one-year transactional history retention, giving one year of Event History backup. Additional event history retention time can be purchased if required, and such purchases will be visible under "Manage License."
Example:
Note: There are currently no configuration specific backups that are retained or that can be restored to reinstate deleted hardware or objects into an instance.
Recommendations:
  1. Exercise caution when deleting objects, especially controllers, from Access Expert. A prompt requests confirmation before deletion.
  2. Generate snapshots of controller configurations and other detailed objects. These snapshots serve as references in case of accidental object deletion, assisting the reconstruction of controllers or other objects with their original configurations.
  3. Summary reports can also be useful when trying to rebuild objects.
    For example: Inputs, Outputs, Readers, etc.
  • EcoStruxure Access Expert
Tags (7)
  • Access Expert
  • AlanWood24
  • backup
  • Deleted
  • instance
  • objects
  • retention
100% helpful (1/1)
