Under objects such as Doors and Inputs what is the "Commands" option used for?
  • Under objects such as Doors and Inputs what is the "Commands" option used for?
  • AdamSteele
    AdamSteele
‎2018-09-06 07:36 AM
Security Expert
Security Expert
Unsure how to use the Commands option showing in some of the objects options.
These cannot be adapted for general use by installers/integrators. These are mostly used for controller instructions that have been included in the firmware but have not been built into the UI yet, as well as internal testing. Leave these alone unless you have a specific need and the instructions from Product Support on how to configure the command.
  • EcoStruxure Security Expert
  • 19349
