Unable to upgrade Continuum DB which fails for SQL Collation Sequence.
  • Unable to upgrade Continuum DB which fails for SQL Collation Sequence.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 12:56 PM
Original database incorrectly built using an improper collation sequence.
  • Continuum
  • SQL
  • DTS
Source database is damaged.
Create new database using Continuum Database Initializer.
Use SQL Data Transformation Services (DTS) to transfer the data from the defective database into the new database.
  • 6843
