Unable to 'unlock latched' a door while REX operation is in progress
  • Unable to 'unlock latched' a door while REX operation is in progress
  • RandyDavis
    RandyDavis
  • PeterEdvik
    PeterEdvik
  • AbeMeran
    AbeMeran
  • David_Kendrick
    David_Kendrick
Captain AbeMeran Captain
‎2022-04-04 01:14 PM
Last Updated: Janeway PeterEdvik Janeway ‎2022-05-17 02:07 AM
The system will not execute an unlock latched command on a door if the door is in the middle of processing a Request to Exit (REX) transaction.  (Client/Server 4.3.308.52    Controller 2.08.1247)
The entry on the Status page below, indicates the system processed the 'unlock latched' command, but left the door in its current state.
This can be problematic when attempting to 'unlock latched' a busy high REX traffic door.
Security Expert
Security Expert Controller
Firmware issue to be addressed in a future release.
The workaround for this issue is to create a Programmable Function to perform the 'unlock latched' when the REX is not active.
1) Make a Virtual Output.
2) Set the Virtual Output's Activation Time to 1 second
3) Create a Programmable Function with the following settings:
            Type:                              Door control
            Door function mode:    2 - Follow pulse on output
            Door control mode:      1 - Latch door unlock
            Output to check:           The virtual output created in step 1)
            Door to control:            The high REX traffic door you wish to 'unlock latched'
Note:
Workaround works for native Security Expert door, do not work for INET transitioned door, a possible solution for INET transitioned door is to convert it to native Security Expert door.
  • EcoStruxure Security Expert
Tags (11)
  • AbeMeran22
  • busy
  • DavidKendrick22
  • door
  • exit
  • high
  • latched
  • request
  • REX
  • traffic
  • unlock
