Unable to successfully connect to a single b3 or i2 controller using a RoamIO.
  • Unable to successfully connect to a single b3 or i2 controller using a RoamIO.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 01:43 PM
I cannot connect to a b3 controller, even when it is removed from the MSTP bus.
I cannot connect to an Infinet controller, even when it is removed from the Infinet bus.
  • Continuum
  • Roam IO
  • MSTP
  • Infinet
  • i2
  • b3
Need to connect with a local controller using RoamIO.
  • In some cases we have found that RoamIO has trouble connecting to an individual i2 or b3 controller.
  • If you are having trouble connecting via RoamIO to a controller that is not connected to the controller bus, try connecting two controllers together and attempting to connect.
  • 5361
