Unable to see all Individuals in a Tenant
  • Unable to see all Individuals in a Tenant
  • Roger_Bently
    Roger_Bently
‎2018-09-06 01:02 PM
Unable to see all Individuals in a Tenant.
All versions of Software and I/NET Seven.
Wanting a print out of all the Individuals in a System.
To display all the individuals in a system, there is no medium in I/NET itself to do this. However there is a report in Seven Reports that will allow this to be accomplished. The following steps shows how this should be done.
  1. Open Up I/Net Seven Data and expand it.
  2. Select the Reports Folder and expand it.
  3. Select the TenantIndividual_xi.rpt and run that.
  4. Enter the parameters and click on the OK button.
  5. Print the results accordingly.
  • TAC INET
  • 6663
