Unable to see Areas when attempting to assign them to Doors
  • Unable to see Areas when attempting to assign them to Doors
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2021-09-19 05:31 PM
on ‎2021-09-19 05:31 PM
When trying to browse for Areas to assign to the Area Inside Door and Area Outside Door fields in Door records, not all Areas are shown or available to be selected.
EcoStruxure Security Expert
Security Expert
The Programming Mode selector is set to "Local" which is the default value. This will only show objects that are already attached to the controller this record resides in.
Programming ModeProgramming Mode
Change the Programming Mode to "Global" which will now show all Area records, including those unassigned or assigned to other controllers.
Programming Mode GlobalProgramming Mode Global
  • EcoStruxure Security Expert
  • AdamSteele21
100% helpful (1/1)
