Unable to save because attached device is not specified error when importing a Continuum Export file.
  • Unable to save because attached device is not specified error when importing a Continuum Export file.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:00 AM
Getting an Unable to save because attached device is not specified error when trying to import a Cyber export file, even when using a file that has just been exported from the same Cyberstation.
  • Export
  • Import
  • 1.9x
Improper path specified.
The problem was resolved by adding the target InfinityController to the path statement.
  • 14538
