Unable to reload or upgrade firmware on a controller.
  • Unable to reload or upgrade firmware on a controller.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:10 AM
Controller drops offline when reloaded or when an attempt to flash firmware is made.
  • Infinet
  • MSTP
Massive CRC errors on the MSTP bus due to a bad controller on one leg of blink.
  • In this case the problem was due to a bad controller on the bus.
  • The offending controller was located by segmenting the bus to determine which legs were introducing this problem.
  • Once it was determined which controller was causing this issue, the controller was removed and a replacement installed.
  • 13993
