Unable to login to servers in Project Configuration Tool(PCT) 2.0
  • Unable to login to servers in Project Configuration Tool(PCT) 2.0
  • StephenYang
    StephenYang
  • RobertAndriolo
    RobertAndriolo
Admiral StephenYang Admiral
‎2024-02-04 10:12 PM
Last Updated: Picard RobertAndriolo Picard ‎2024-07-18 03:55 PM
Fail to login to the selected server when the User name and Password are correct.
Project Configuration Tool 2.0
In the example, the Server is in EBO 3.2.1.630 and the Workstation is 3.2.3.59. The Workstation is at a higher version than the Server but it's not the latest version. PCT loads the incorrect IP(192.168.10.2) in the WS due to the version.
PCT requires to use of the latest version of WorkStation for all releases (3.2, 4.0, 5.0, 6.0).
For example:
EBO 3.2.1.630, 3.2.2.61, 3.2.3.59 and 3.2.4.1009 use WorkStation 3.2.4.4007(CP2) or above.
EBO 4.0.1.86, 4.0.2.559, 4.0.3.176, 4.0.4.45 and 4.0.5.7 use WorkStation 4.0.5.3004(CP2) or above.
Labels (2)
  • Project Configuration Tool
Tags (2)
  • RobertAndriolo24
  • StephenYang24
56% helpful (5/9)
