Unable to connect to b3xxx controllers with RoamIO.
  • Unable to connect to b3xxx controllers with RoamIO.
  • AdamSteele
    AdamSteele
‎2018-09-06 10:12 AM
RoamIO-1
RoamIO-2
The RoamIO-1 is not able to communicate with BACnet controllers. It only supports Infinet controllers.
The RoamIO will not be able to communicate with the BACnet controllers (bCX4040, b3xxx, etc...) you will need to use the RoamIO-2 that is able to communicate to both Infinet and BACnet.
  • 13874
