Unable to connect to Infinet Roam IO 2 tool using Windows 7 / Update fix
  • Unable to connect to Infinet Roam IO 2 tool using Windows 7 / Update fix
  • Chris_Asbury
    Chris_Asbury
  • CraigEl
    CraigEl
‎2018-09-10 01:38 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-11 07:46 PM
When using the Roam IO 2 tool, you are unable to connect to the controller using the infinet tool, but you can connect using the BACnet tool.
Bluetooth has connected fine using both tools.
  • Windows 7
  • Roam IO 2
  • Infinet
  • BACnet
This issue is due to a firmware mismatch.
There is a new version of the RoamIO tool firmware available,
You must update to this version for the tool to connect correctly.
  1. Download the update RoamIO tool here.
  2. Using a 3rd party unzip program, Unzip the file.
  3. Update the Roam IO 2 tool with the Roam IO 2 connected
  4. Using the BACnet RoamIO software, goto tools and then update.
  5. Select the update .UPD file you have just downloaded, this will flash upgrade the Roam IO 2 to the latest firmware
RoamIO2Appl2.000002.zip
Tags (2)
  • 11538
  • continuum
