Unable to connect to AS version 1.5.0 and below with Device Administrator
  • Unable to connect to AS version 1.5.0 and below with Device Administrator
  • Tom_Poovey
    Tom_Poovey
  • RobertAndriolo
    RobertAndriolo
  • Benji
    Benji
‎2018-09-06 09:01 AM
Even though the correct settings are defined in Device Administrator, the Automation Server will appear red indicating that it is not possible to connect to it.
  • AS
  • Device Administrator
Some special characters are not supported in some positions before version 1.6.0. For example, the password admi$n would work in Workstation, but not in Device Administrator. The password admin$ would however work.
Furthermore, after 3 login attempts the account will be blocked.
  1. Change the admin password to something simple like "admin" or "password"
  2. Reboot the AS, or wait 30 minutes
  3. Connect with Device Administrator
  • 17924
