Unable to commission Xenta 913 in EcoStruxure Building Operation
  • Unable to commission Xenta 913 in EcoStruxure Building Operation
  • Jonas_Brissman
    Jonas_Brissman
  • HenrikTarpgaard
    HenrikTarpgaard
‎2018-09-06 09:54 AM
Last Updated: Janeway Jonas_Brissman Janeway ‎2022-08-12 02:21 AM
If a Xenta 913 with SNVT(s) is added as a Lon device to an Automation Server Lonworks network the commission process fails in the last step with error 0
  • Building Operation Automation Server
  • TAC Xenta 913
  • TAC Xenta 700
This is a bug in the Xenta Server firmware.
This issue will be fixed in Xenta 913 firmware version 5.1.9, however  hotfixes have been made for 5.1.8 and can be requested from PSS (TACXenta913-5.1.8.15 and TACXenta700-5.1.8.47).
Note: All data will be lost in the Xenta Server when applying the hotfix.
Labels (2)
Tags (2)
  • 14913
  • JonasBrissman22
