Unable to Run WebStation on Windows Server 2008
  • Unable to Run WebStation on Windows Server 2008
  • Derrick_Ratliff
    Derrick_Ratliff
  • Benji
    Benji
  • CraigEl
    CraigEl
‎2018-09-10 12:28 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 04:46 PM
TAC Vista
  • Vista Webstation 5.1.6
  • IIS
  • ASP.net
IIS 7 and ASP.net must be installed before Vista Server in order for Webstation to function
  1. Uninstall Vista Server as outlined in How to uninstall and completely remove TAC Vista 5
  2. Install IIS 7 and ASP.net
    1. Start the Server Manager
    2. Right-click Roles
    3. Click Add roles
    4. Select Web Server (IIS)
    5. In the following dialog click Add Required Features
    6. Click Next (twice)
    7. Select ASP.net
    8. In the following dialog click Add Required Role Services
    9. Click Next
    10. Click Install
  3. Install TAC Vista Server
  4. Install TAC Vista Webstation
  5. As administrator, Run the ASP.NET IIS Registration Tool (Aspnet_regiis.exe) for ASP.NET version 4.0
    1. %SystemRoot%\Microsoft.NET\Framework\v4.0.30319\aspnet_regiis.exe -i -enable
    2. 64-bit OS: %SystemRoot%\Microsoft.NET\Framework64\v4.0.30319\aspnet_regiis.exe -i -enable
  • 5798
