Unable retrieve objects from a third party device that has been added to Continuum.
  • Unable retrieve objects from a third party device that has been added to Continuum.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:21 AM
Continuum found and added both third party chiller controllers, RLE LD5200.  When a send to database is executed however, no objects are added to the Continuum database.
  • BACNet
  • RLE LD5200
Some BAS systems use a 16 bit identifier while Continuum uses 32 bits.
Problem resolved updating the third party controller firmware..
  • 13413
