UI-8-10 does not update input values in Continuum.
  • UI-8-10 does not update input values in Continuum.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:50 AM
UI-8-10 module is reporting no change of state on inputs when shorted.
UI-8-10
Setting the voltage range switch to 10V when the Reference Resistor is in the on position is an invalid configuration.
Change the voltage range settings to 5v on the input.
  • 11943
