Try to create new ContinuumDB with Database Initialization and receive Database creation failed error stating the database does not exist.
  • Try to create new ContinuumDB with Database Initialization and receive Database creation failed error stating the database do...
  • AdamSteele
    AdamSteele
‎2018-09-06 12:19 PM
On attempted creation of new database receive the below errors.
Database creation failed.
Installation Error! <[Microsoft][ODBC SQL Server Driver][SQL Server]The database 'ContinuumDB' does not exist. Supply a valid database name. To see available databases, use sys.databases. >
Installation Error! <[Microsoft][ODBC SQL Server Driver]Invalid cursor state>
Continuum Cyberstation
The "DB File Location" in the Database Initialization dialog is not specified properly.
  1. Check where the "Data" folder resides on the SQL server
    A typical SQL Express install will have this located at "C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\Data" but depending on the type of SQL, Operating System, and if any other instances of SQL - this location could be different.
    The correct folder contains at least six files:
    • master.mdf
    • mastlog.ldf
    • model.mdf
    • modellog.ldf
    • tempdb.mdf
    • templog.ldf
  2. Type this path location into the "DB File Location" field
  3. Re-attempt the Database creation.
  • 7991
