Transitioning Continuum access control related objects into AccessXpert sub instance
  • Transitioning Continuum access control related objects into AccessXpert sub instance
  • AbeMeran
    AbeMeran
  • JohnBoehmer
    JohnBoehmer
Captain AbeMeran Captain
‎2020-06-23 06:07 AM
on ‎2020-06-23 06:07 AM
Getting error 'One or more errors occurred' when transitioning Continuum access control related objects into AX sub instance.
In the screenshot above, the tool is attempting to transition objects into the PSS sub-instance under the root instance.
Access Expert
  • Access Expert Premise Software
  • Access Expert Hosted Software
The transition tool GUI is misleading in terms of where specific information should be entered.
Due to an issue in the tool, only the instance field should be populated, in the case of a sub-instance specify the name of the sub-instance in the 'Instance' field.
Labels (2)
  • EcoStruxure Access Expert
Tags (2)
  • AbeMeran20
  • Continuum Transition AccessXpert AX
