Transferring VisiSat Licenses Between PCs
  • Transferring VisiSat Licenses Between PCs
  • CraigEl
    CraigEl
‎2018-09-07 02:11 PM
Last Updated: Administrator CraigEl Administrator ‎2025-11-10 09:05 PM
Users need to transfer VisiSat licenses from one PC to another, typically due to hardware replacement or system upgrades.
Satchwell MicroNet
Satchwell VisiSat 2.x
Licenses are tied to the original PC and must be exported and re-imported to function on a new machine. This process is necessary when:
  • Replacing or upgrading a PC
  • Consolidating engineering tools
  • Migrating from VisiSat v2.0 to v2.1
Follow these steps to transfer VisiSat licenses:
  1. Export License from Original PC
    • Use the VisiSat license management tool to export each license file.
    • Save the exported files to a secure location (e.g., USB drive or network share).
  2. Transfer License Files to New PC
    • Copy the exported license files to the target PC.
  3. Import License on New PC
    • Use the license management tool on the new PC to import the license files.
    • Ensure VisiSat v2.1 is installed before importing v2.0 licenses.
  4. Reference Documentation
    • For detailed steps, refer to the Moving VisiSat Licenses PDF extracted from the VisiSat Engineering Guide.
    • Also see: Transferring VisiSat version 2.0 license to Computer running VisiSat 2.1
  • Satchwell MicroNet
Tags (2)
  • 4904
  • CraigEllis25
