The uprev code could not open the specified UDP file error when attaching the xdriver file to a comm port.
  • The uprev code could not open the specified UDP file error when attaching the xdriver file to a comm port.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:32 AM
Enabled xdriver support on the controllers with the xdriver flash file.
Comm port mode has been set to xdriver, but when the xdriver fill is attached the following error occurs.
  • xdriver
  • Comm port
Incorrect file path or file name used.
Rather than typing in the xdriver file path and location, select the browse button and browse to the file location.
  • 12871
