The time of DCU will change automatically for specific period
  • The time of DCU will change automatically for specific period
  • Tom_Poovey
    Tom_Poovey
  • CraigEl
    CraigEl
  • sesa145087_brid
    sesa145087_brid
‎2018-09-06 01:10 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 10:49 PM
Under multiple PC environments, the time of a DCU changes automatically for a specific period. The time of the Server/Filemaster is correct.
TAC INET
  • I/NET
  • Multiple PCs environment
For multiple PC environments, the time setting of each PC does not synchronize. The time of Server/Filemaster is correct, but the time of Remote Client/Equalized Client may be not correct. If there is a DCU Synchronization function set on the Remote Client/Equalized Client, the wrong time will synchronize to the DCU for specific period set in the function of DCU Synchronization.
Synchronize the time on Remote Client/Equalized Client with Server/Filemaster through NTP or manually. The other way is only to set DCU Synchronization function on Server/Filemaster, not on Remote Client/Equalized Client.
The NTP as of March 1, 2013 no longer works. See Time sync is no longer working for suggestions
  • TAC INET
Tags (7)
  • 12422
  • 6424
  • Equalized Client
  • File Master
  • ntp
  • Remote Client
  • time sync
