The stopwatch object in VisiSat operates erratically when set to trigger on days.
  • The stopwatch object in VisiSat operates erratically when set to trigger on days.
  • CraigEl
    CraigEl
  • Gary
    Gary
‎2018-09-10 07:00 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-26 03:30 PM
The Stopwatch object in the VisiSat Bubbleland object list behaves erratically when configured to trigger on a daily basis. Specifically, when set to issue a pulse once per day, it may issue multiple pulses (2–3 times) within the same day.
Satchwell MicroNet
  • VisiSat
This is due to a software/firmware error.
Note: No fix is currently planned.
Avoid using days as the unit for the stopwatch trigger. Instead, use hours to achieve the desired timing:
  • Replace 7 days with 168 hours
  • Replace 14 days with 336 hours
If you need to display the value as days or weeks in MicroNet View, follow these steps:
Steps to Convert and Display in MicroNet View
  1. In VisiSat:
    • Locate the Stopwatch object
    • Add the Stopwatch Rollover to the points list
    • Go to Tools > Export and export the points list to MicroNet View
  2. In MicroNet View (Development Mode / Window Maker):
    • Open the relevant window
    • Add a text field (e.g., "###") to display the value
    • Add the tag for the stopwatch rollover value
    • To display the value in weeks, append /24 to the tag name
    Example:
    TagName/24
  3. Using a Data Change Script:
    • Create a tag with appropriate min/max values
    • Add a data change script to convert and display the value in weeks
    • Set the "###" field to User Inputs > Analog
    • Link it to the data change tag
  4. To Set Rollover in Days:
    • Click the days set area
    • Enter the desired number of days
    • Press Return to confirm
    ⚠️ Remember: The controller stores the value in hours (e.g., 14 days = 336 hours). The conversion to days is only for display in the MicroNet View interface.
  • Satchwell MicroNet
Tags (2)
  • 7293
  • CraigEllis25
