The "MyGet" site used by SmartConnector developers is now replaced by GitHub
  • The "MyGet" site used by SmartConnector developers is now replaced by GitHub
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2025-09-11 05:13 AM
Last Updated: Administrator CraigEl Administrator ‎2025-09-11 05:16 AM
The MyGet site previously used by SmartConnector developers to access NuGet packages has been shut down. Developers now need an alternative source for these packages.
Building Operation SmartConnector
NuGet is a package management system for .NET that simplifies development by providing access to pre-built libraries and tools. With MyGet no longer available, developers must transition to a new package source.
SmartConnector NuGet packages are now hosted on the GitHub Package Registry. Follow these steps to configure access:
Step-by-Step Instructions
    1. Create a GitHub Account
      • Visit github.com and sign up using your email address.
    2. Generate a Personal Access Token
      • Navigate to Developer Settings.
      • Click Generate new token (Classic).
      • Under Select scopes, check:
        • read:packages (required)
        • write:packages (optional, for publishing)
      • Name your token and set an expiration.
      • Click Generate and copy the token immediately (you won’t be able to view it again).
    3. Configure Visual Studio
      • Open NuGet Package Manager.
      • Add a new package source:
        • Name: SmartConnector GitHub
        • Source:
          https://nuget.pkg.github.com/SchneiderElectricBuildings/index.json
    4. Authenticate
      • When prompted:
        • Username: GitHub username or email used to sign up.
        • Password: Your Personal Access Token.
    5. Access the Package
      • Once authenticated, you should see the latest SmartConnector NuGet package:
        v2.5.5.108
Important Notes
  • All future SmartConnector packages released by the R&D team will be published via GitHub.
  • Ensure your token permissions are correctly set to avoid access issues.
  • JonasBrissman25
