The folder name is included in the binding even when using relative path.
  • The folder name is included in the binding even when using relative path.
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:27 AM
When doing a binding using relative path the folder name is included in the binding.
When clicking on the relative path button the binding looks like it should without the folder name but it is no possible to save it like that.
StruxureWare version 1.3
In the folder name a space was used.
When taking away the space in the name the relative bindings looked like the should, no folder name in them.
  • 13101
