The difference between using "Control Output" and "Input Control Output"
  • The difference between using "Control Output" and "Input Control Output"
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2021-04-12 03:04 PM
When configuring an Input to control an Output in an Input Type, what are the differences between using the "Control Output" or "Input Control Output" options?
EcoStruxure Security Expert
Security Expert
When configuring Input Types there can be some confusion with the terminology used to describe the two types of Outputs that can be controlled from an Input event.
Control Output options on the Input Types Options (2) tabControl Output options on the Input Types Options (2) tabInput Control Output options on the Input Types Options (3) tabInput Control Output options on the Input Types Options (3) tab
  1. The "Control Output" options refer to the Control Output defined in the Input Type's General tab.Control OutputControl Output
  2. The "Input Control Output" options refer to the Control Output defined in the individual Inputs General tab.Input Control OutputInput Control Output
An explanation for a related example would be:
  1. If a common output for all inputs of the Input Type then;
    1. On the Options (2) tab enable the Activate Control Output On Alarm and Deactivate Control Output On Restore.
    2. On the Configuration tab of the Input Type, set the Control Output to the output you want to trigger.
  2. Else if each input has a separate output then;
    1. On the Options (3) tab enable the Activate Input Control Output On Alarm and Deactivate Input Control Output On Restore.
    2. In each Input set the Control Output to the output you want to trigger.
  • EcoStruxure Security Expert
  • AdamSteele21
100% helpful (1/1)
